Low coolant light
Old May 2, 2007 | 02:33 PM
GrampsC4's Avatar
Default Low coolant light
1987 "vert"
My low coolent light in thedash display will say "low coolent" when car is first started.Light goes out after 5 or 10 minutes of driving.
Temp gage shows car running cool,hi 180's to mid 190,s under normal use.On hot days at idel,highest its ever read was around 225.Fan kicks in,temp drops as it should.But it'll still say's low coolant at first 5 or 10 minutes.Coolent level is good.
Thinking bad sensor.Any suggestion's would be appreciated.
Also,where is sensor located?
Old May 2, 2007 | 05:36 PM
mikenann's Avatar
Default RE: Low coolant light
I have a 87 also had the same problem. It was the sensor. It is on the passenger side of the radiator at the top. Easy fix and cheap. Don't have to drain any fluid or anything.
Mike
Old May 2, 2007 | 09:42 PM
Ditto.
Old Oct 15, 2007 | 11:56 AM
C4land's Avatar
I replaced the sensor (twice) in my 89 and after driving it for a month the light still comes on. There must be a relay somewhere in that mess that causes this.
shaggy34994
Feb 21, 2013 09:05 AM
C4land
Feb 3, 2008 10:51 AM
87LtdT
Dec 31, 2006 04:57 PM
GrampsC4
Sep 19, 2006 09:48 AM
tankerpilot01
Oct 25, 2005 08:24 AM
