windshield wipers
Old Oct 23, 2005 | 10:58 PM
keverson's Avatar
Default windshield wipers
I can't figure these things out yet! The only way to open the wiper door on my '71 is to pull the manual switch under the steering column. The wiper switch clicks at the wiper motor, but it won't open the door. Once the door is opened manually, the only way to engage the wipers is to push and hold the wiper/washer switch. Any experts out there who understand these things?
Old Oct 24, 2005 | 03:38 PM
red70vet's Avatar
Default RE: windshield wipers
You have touched upon one of the most troublesome areas of the Corvette world the dreaded Headlight / wiper vaccum system. If you goggle Corvette headlight and wiper system you will come accross endless conversation and article on troubleshooting. Here is one which should help your particular problem-http://www.corvettefaq.com/c3/wiperdoor.htm
This system is complicated but once you figure it out it is relatively easy to diagnose problems.
Old Oct 24, 2005 | 10:39 PM
keverson's Avatar
Thanks! This should keep me busy for a while.
Old Nov 2, 2005 | 11:18 PM
johnc's Avatar
had similar problems with my early '71,learned a lot the hard way.if you can open door with pull down switch,it means you have at least some vacuum to system,i strongly suspect the little vacuum switch in wiper compartment located on pass.side.if this is defective,wipers won't operate.the reason they work when you hold wash position is a different function of wiper motor itself..good luck jc
Redwhisper
Jan 31, 2009 06:52 PM
pookie16
Jun 2, 2007 07:17 PM
mlrutland
Feb 17, 2006 09:52 PM
redvet
Dec 17, 2005 02:20 PM
Sandy2525
Jun 30, 2005 07:15 PM
