(MAF) mass air flow sensor making nois
Old Sep 6, 2007 | 07:39 PM
iresolver's Avatar
Default (MAF) mass air flow sensor making nois
can the MAF mass air flow sensor be fixed
and does any one know how to do it?
[IMG]local://upfiles/6301/09B9278603EF419D93ADF0385C1F9898.jpg[/IMG]
Old Sep 6, 2007 | 08:23 PM
rshiver's Avatar
Default RE: (MAF) mass air flow sensor making nois
If they can be fixed, I've never heard of it. What kind of noise is it making? Have you checked to make sure something hasn't gotsucked up against the screen? Is it affecting the way the engine runs?
Old Sep 6, 2007 | 08:47 PM
iresolver's Avatar
it is making a high pitch sound like steam coming out under high pressure
Old Sep 6, 2007 | 08:53 PM
iresolver's Avatar
I think I had a problem like this in one of my camaro's it had the same engine as the corvette
it looks like I will have to buy the MAF for about $219.00 from zip products
do you know any good place to buy corvette parts that might be cheaper?
Old Sep 7, 2007 | 06:41 AM
rshiver's Avatar
ORIGINAL: iresolver
Another thought here,... are you sure it's not the pressure release valve on your AC blowing off?, it will do that if the systems head pressure gets too high. Is your radiator cooling fan coming on when you turn on the AC? Like I said...just a thought.
Old Sep 8, 2007 | 06:39 AM
If it only makes the sound while engine running, check the intake boot on both sides to make sure the orings are still there and for proper seal. Sounds like its sucking air in.
Old Sep 8, 2007 | 10:10 PM
ORIGINAL: iresolver
What's up with the motor? Poor tune? Any codes lit up on the dash?
I don't think you oughtta' dump any cash yet, without knowin' for sure whatcha' got there...
sundaymoney
Aug 13, 2008 09:51 PM
mypetu39
Jul 5, 2007 03:48 PM
liviz40102
Aug 14, 2006 04:20 AM
PAULKR
Sep 11, 2005 05:49 PM
