hard Water Leak
Old Oct 7, 2007 | 07:28 AM
nasapaul60's Avatar
Default hard Water Leak
I have the 2003 Corvette Convertible (anniversary). Now,when it rains hard I find wateron the drivers side. Can anyone tell me what to check?
Old May 27, 2008 | 04:23 PM
byronhunter's Avatar
Default RE: hard Water Leak
Check this out, Bill Curlee is as good as it gets. Lots to read!
http://forums.corvetteforum.com/show....php?t=1246715
Old Sep 1, 2008 | 01:13 PM
David Jones's Avatar
Not sure if this is the cause but there are cowl drains that tend to clog with leaves. They are on the driver side you can clearly see them from under the car behind driver side wheel. (they have been described as utters). I found mine clogged the hard way. Windshield wipers failed due to corrosion in wiper control module. I had to remove wiper drive and re-solder board under motor assy .
sc6654
Jan 4, 2008 10:23 PM
limey
Dec 25, 2006 09:59 PM
limey
Nov 28, 2006 03:12 PM
dcd58
Nov 12, 2005 09:22 AM
dcd58
Nov 10, 2005 08:49 PM
