SYS Flashes on dash
Old Mar 2, 2008 | 10:43 AM
bucketman's Avatar
Default SYS Flashes on dash
Just bought this cherry 96 LT4 convert last October. I got to put 600 miles on it and put it away for the winter as I live in lovely Wisconsin. I start it up about every 2 weeks and bring it up to operating temp and let it run about 30 minutes. The last time I started it I got a SYS symbol flashing were the temp readout is. Question is,has anybody else had this happen and what did it turn out to be? The engine and all the componets work fine, ie radio, ac, fans. Would appreciate any info.
Jim
Old Mar 2, 2008 | 05:12 PM
Viscount's Avatar
Default RE: SYS Flashes on dash
Probably a "Lo" battery condition. Assume your not using a trickle charger or such?
I would buy a Battery Tender & keep it attached to the battery when not in use &that shud solve the problem as you are unable to drive the car. Running it for 30 minutes IMO is not recommended to charge the battery.
Doesn't take much to get the "SYS' started.
Old Mar 2, 2008 | 08:09 PM
bucketman's Avatar
Thanks Viscount, I started it today and did not have a sys. I think you are absolutely correct on this one. Can't hardly wait to get her out again. Baaad winter this year.
Jim
Old Mar 2, 2008 | 08:12 PM
LeesVette's Avatar
Definetly a battery issue.
Old Mar 2, 2008 | 08:22 PM
Viscount's Avatar
ORIGINAL: bucketman
Jim
Hang in there. It won't be long before your hittin the road again.
Jordan
Aug 11, 2007 03:11 PM
dougq
Jul 12, 2007 05:52 PM
okvette92
Apr 14, 2007 06:47 PM
deansreef
Apr 2, 2007 09:35 PM
ARCTIC94
Nov 17, 2005 03:19 PM
