66 Power antenna ground strap
In the process of replacing the the ground strap on the supporting bracket for the power antenna. According to the factory assembly manual, one end attaches to the support bracket —-the question is where does the other end attach to? Frame ? where
A
A
Yes. Ground strap attaches to the inside part of frame just behind the rear driver tire. Should see a threaded hole there. You may also see some white markings in that area. I just pulled out my old unit so I know exactly where the ground strap on a '66 attaches to.
