66 Power antenna ground strap
Old Dec 7, 2020 | 06:33 PM
Steve29cars's Avatar
Default 66 Power antenna ground strap
In the process of replacing the the ground strap on the supporting bracket for the power antenna. According to the factory assembly manual, one end attaches to the support bracket —-the question is where does the other end attach to? Frame ? where
A
Old Dec 9, 2020 | 12:04 AM
Best guess would be the closest part of the frame or some metal part connected to the frame. Look for an unused hole.
Old Jan 27, 2021 | 10:34 PM
mogy66's Avatar
Yes. Ground strap attaches to the inside part of frame just behind the rear driver tire. Should see a threaded hole there. You may also see some white markings in that area. I just pulled out my old unit so I know exactly where the ground strap on a '66 attaches to.
dans87vette
Aug 5, 2007 07:02 PM
xBIGxBENx51
Jul 29, 2007 09:06 PM
jmtrotzie
Apr 27, 2007 08:11 PM
johnfrit
Aug 17, 2006 02:44 PM
johnfrit
Aug 12, 2006 12:05 AM
