67 corvette 427 numbers
Old Feb 15, 2026 | 02:33 PM
k19sib's Avatar
Default 67 corvette 427 numbers
Hi I am new to this Forum I live in the UK i have just purchased a 67 427 corvette numbers matching car but having a problem with the numbers on the car it has a tri power set up on it the numbers i have are as followed engine no on front pad and on tag under glove box 714 IL 7102449 on the block by Bell housing casting 0904351 I dropped the pan and it has 4 bolt mains it has the HI PERF casting on block and has the plug for the oil cooler by the oil gauge pipe by the oil filter 80lb oil gauge 6500 tac what i ham confused about is the IL I thought this was for the 390hp car much appreciate the help thanks Keith
Old Feb 15, 2026 | 08:32 PM
Congratulations on your Purchase. And Welcome to the forums. The block casting number is likely to be a 67 427 (2 or 4 bolt main) number #39044351, the 0 in front of the 9 is likely a 3. lt's hard to read sometimes. Often times when engines are torn down and machined, they deck the bock and grind the numbers off, a sad consequence when numbers matter. The 1L refers to 1-Coupe and L-Built in St. Louis. Standard engine was a 300-hp 327-cu.in. v8. No mention of the 427 option in the serial number, Which seams odd but maybe that was normal for that year of a C-2. I might need to check on that.
Old Feb 15, 2026 | 09:00 PM
From what I can find from 1965 to 71 they didn't list the engines in the serial number just that it's a V8. Unless you have original paperwork conferming its original, I don't know how to prove that it is original engine. But it does have a 1967 casted block without matching numbers.
Old Feb 16, 2026 | 02:44 AM
k19sib's Avatar
Default 67 427 numbers
thanks for the reply sorry i should have said the car is a convertible the engine has not been Decked still has the broach marks across the numbers on the engine pad it has 4 bolt mains see pictures
Old Feb 16, 2026 | 06:06 AM
Good pictures. Breaking down the engine numbers 714 are casting numbers, The IL suffix code typically indicates the engine configuration 427 and the L36 variant which produced 390 HP in which 5,000 were produced. There's a lot of information out there if you want to know more. And yes that is a engine matching number. I would say it's a keeper.
Old Feb 16, 2026 | 08:15 AM
k19sib's Avatar
Hi Thomas just got some paint stripper on the number on the block it is a 3 but on this web site many people say 390hp cars don't have 4 bolt mains and they don't have the oil cooler plug by the oil filter witch this one does thanks Keith
Old Feb 16, 2026 | 02:32 PM
Welcome to the forum, Keith. Good luck on your project, sounds like a keeper. BTW, very nice looking car.
Old Feb 16, 2026 | 05:19 PM
Well it looks like it's the L71 variant 435HP. Nice.
dean2804
Aug 3, 2021 01:29 AM
burtonsautomotive
May 25, 2018 06:48 AM
zzfranczz
Sep 2, 2009 02:58 AM
flyboy1024
Feb 9, 2008 01:12 AM
Wedge
Nov 19, 2005 02:33 AM
