Decoding GM Engine sufix - CRE
Old Oct 29, 2018 | 11:36 AM
Farmone's Avatar
Default Decoding GM Engine sufix - CRE
Can anyone decode the suffix on my GM small block engine? T0707 CRE is stamped on the front of the block. 3970014-? is cast on the bell housing flange. Thanks.
Old Oct 29, 2018 | 08:40 PM
Farmone's Avatar
Default Thanks Keen Corvette Parts
I am blessed to have Keen about 5 miles from my home. They identified my engine as a 1970 350 Turbo, 300 hp out of a Chevelle. I stopped by for a fuel filter kit. Great bunch of guys! Yes, I would have preferred it to be a match number 327.
Old Oct 30, 2018 | 09:15 AM
If it has an 8" harmonic balancer, that usually means it was the high-performance version of the engine.
Did they tell you what heads it had on it?
What car is the engine in now?
Old Nov 1, 2018 | 01:09 PM
Farmone's Avatar
I have to pull the covers to accurately identify the heads; they do have the double hump. Engine is in a 65' C2. 4-spd Tranny matches the car vin. Still working on identifying matching numbers - haven't found a real good number decoding source yet.
Old Nov 1, 2018 | 06:29 PM
If the double hump heads have a rounded hump on the top, then they are the high compression big valve heads. If the double humps are pointed on top, then they are the low compression big valve heads. The intake valve would be 2.02", and the exhaust valve would be 1.7".
Old Nov 1, 2018 | 06:59 PM
Check chevyresource.org and click on Corvette for casting number decoder.
Carl45
Mar 31, 2016 09:29 PM
americansteel
Aug 3, 2011 08:39 PM
19vetteman67
Jun 22, 2011 03:36 PM
Silver Vette
Oct 8, 2007 07:54 PM
Binderbird
Mar 19, 2007 09:02 PM
