Knock-off Wheel Problem
Old Jan 5, 2010 | 12:02 PM
vdesantis's Avatar
Default Knock-off Wheel Problem
I have a1966 coevette with older repro knock-off wheels; I can't get the front passenger side off using a special wrech and 5 ft. lenght of pipe...any suggestions?
Old Jan 5, 2010 | 03:49 PM
partsman41's Avatar
Probably need to put on some penetrating oil,I like PB Blaster or a 50/50 mix of acetone and ATF. Then apply some heat to the nut,spinner whatever you call it. Maybe several heat-cool cycles with penetrating oil applications. You needn't get really crazy with the heat,don't blue the chrome or melt anything! Try to remove it while hot,should expand it a little and help.
Ron
Old Jan 15, 2010 | 04:01 PM
I'm surprised that you aren't twisting off the studs w/ a five foot pipe. I guess that could be you're last ditch effort.
Have you tried an impact wrench?
Old Jan 15, 2010 | 07:34 PM
partsman41's Avatar
73 shark: he's got the one big nut in the center deal.
vdesantis: Have you got it off yet? Of course an impact wrench is pretty helpful in situations like this but what would it do to the nut? Do you have a wrench or socket that would let you use an impact? If the socket will work you could probably talk the local tire shop into hammering it off for you?Surely you're turning it the right way? (Please don't be offended,,these things happen!)
Of course the obvious suggestion would be"Get a TEN foot piece of pipe!"
Ron
Old Jan 16, 2010 | 02:23 PM
So you're saying that he has the repo KOs that use the spinner that requires the lead hammer to remove? Guess I couldn't picture how he managed to get a pipe on it if that's the case. But like you said, they are left-hand threaded on one side but I don't remember which side that is. Maybe they're marked.
Old Jan 19, 2010 | 07:51 AM
vdesantis's Avatar
Default What I've done to remove wheel
I used a special wrench that Dennis Portka sells. It fits over the 3 spinner legs and has a 1" handle about 15" long; I put a 5' length of 1-1/4" black pipe over it and it doesn't budge. I tried 2 kinds of penetrating fluid multiple times. I drilled holes in a number of spots thru the threads that have the semi-circle for lining up the safety pin and squirted fluid in them. I used mild heat from a hand held propane torch. I know which way it threads as its marked on the nut; I removed the other 3 wheels. When I told my tire guy waht I did, he wouldn't even try; he said take it to a body shop and have them heat it with a torch. I'm ready to cut it off myself. Thanks for your help/responses!!
Old Jan 24, 2010 | 10:40 AM
Is there anyway that you could couple an impact wrench to the spanner wrench? Sometimes just let an impact wrench hammer away at a low setting w/ break 'em loose.
Old Jan 26, 2010 | 09:50 AM
vdesantis's Avatar
Thanks but I can't think of any way to do that right now but I'll give it some more thought.
gep10
May 6, 2013 12:46 AM
07c66speed
Corvette C6 Z06
May 2, 2007 01:49 AM
bill
Jul 8, 2006 12:18 PM
mjjansson
May 23, 2006 03:25 PM
faspgh
Sep 24, 2005 02:48 AM
