Plug wires take more time to change...
Old Aug 20, 2007 | 09:32 AM
scottr65's Avatar
Default Plug wires take more time to change...
We did a tune up and an alignment on the '65 coupe. Our plan was for about 2 hours total. It turned into over 4 hours! We did not know that two plug wires on each side run through the motor mounts. You have to undo the mounts and jack the engine about an inch. Plus we have all of the ignition shielding in place, which adds more time as well. One shield on each side shares the motor mount bolt, which makes it even more fun when trying to lineup the engineand get the bolt threaded. :-)
We just wanted to pass this on for anyone planning on changing plug wires on a mid year.
Old Aug 20, 2007 | 09:38 AM
ax's Avatar
ax
Default RE: Plug wires take more time to change...
Yep....it'll make you buy the best wires you can find!
Old Aug 20, 2007 | 02:02 PM
scottr65's Avatar
It was worth it! A couple wires were not even clamping down tightly on the plug. It's no wonder it sounded like only 6 or 7 firing most of the time. She runs great now.
Old Aug 20, 2007 | 03:05 PM
ax's Avatar
ax
Good to hear.....it's always good to get performance results from somthing as simple(well usually simple) like a plug and wire change.
Old Aug 20, 2007 | 03:54 PM
78buckshot's Avatar
The small block C3's are the same, plug wires through the engine mount.
badbluez00
Jun 4, 2022 03:52 AM
Jim2001c5 pilot
Jul 1, 2007 01:53 PM
halbert
Nov 5, 2006 12:30 PM
94blackC4
Sep 25, 2006 09:35 PM
Petew1971
Mar 9, 2006 03:08 PM
