1969 tri-power for 435hp turbo 400 automatic car
Old Feb 25, 2008 | 11:53 AM
elsie1969's Avatar
Default 1969 tri-power for 435hp turbo 400 automatic car
i am restoring a 1969 convertible built in August with a rare combo: 435 h.p. L71 motor and turbo 400 transmission. Would the center Holley carburetor be part number 4055 or 4056? Does anyone out there have one like this? i was told there are only about 250 built with this combination. Little black book says 4056 is for automatic but 4055 is for 435hp???
Old Feb 25, 2008 | 09:11 PM
Default RE: 1969 tri-power for 435hp turbo 400 automatic car
Welcome to the Corvette Forum.
According to my old GM Parts Catalog, the R-4056-1A (3940929) for the TurboHydramatic and the R-4055-1A (3955205) is for the 4 spd. These are both called the primary which if I remember correctly is the center carb and the end carbs are vacuum actuated as opposed to a progressive mechanical linkage. The P/Ns are circa 1974 so probably aren't valid anymore for GM. But the Holley numbers don't usually change so you can probably find them. May need a home equity loan tho.
What a great rare car. Be sure and post some pics when you can.
Old Feb 27, 2008 | 08:58 AM
elsie1969's Avatar
Thanks for the reference. I have acquired both center carbs, dated within 3-4 months prior to car build date (i was toldNCRS gives you a six month window on dates, and there was a UAW strike mid-1969 for almost two months between part build and my corvette build date). i just wanted to install the right center carb and sell the other one. Now I need to find a original 427 hood, exhaust mainifold and the rate A.I.R. system before repaint. It is a one owner car, except the original owner (me) was young and dumb!The only change is now I am no longer young.
Old Feb 27, 2008 | 09:09 PM
That's great. Another original owner. That makes at least two of us. As I'm sure you know the parts to bring up to NCRS standards are expensive. []
You certainly have a rare car. Enjoy it.
Stovepipe
Oct 28, 2008 08:15 PM
tripowerrookie
Sep 11, 2008 07:41 PM
RapidRuss
May 19, 2007 10:43 PM
Black Cloud
Nov 18, 2006 08:28 PM
