1970 454 Ignition Points or transitor?
Old Apr 28, 2019 | 04:09 PM
1970LS5's Avatar
Default 1970 454 Ignition Points or transitor?
All, I am reading that early year has Points and later transistor ignition.
True? If so how do I identify? Some of the electrical diagrams indicate a Pulse Amplifier is associated with the transistor type and it is a separate box with a 3 prong plug. Is this located engine bay side or under dash?
Does the Transistor Type use a magnetic or hall effect type distributor instead of points??
Is the resistor type wire going to (+) side of coil unique or different? Color, cloth insulation stripes etc?
Thx
Old Apr 29, 2019 | 10:08 AM
Welcome to the forum. Not sure about the 1970 454 ignition but I know the mid-year 427 had it as an option. The control unit was mounted on the driver side on the front of the radiator support. The distributor used a toothed wheel, magnetic type pickup. I suspect that they continued using that version through the early 70s but not sure.
1970LS5
Apr 29, 2019 09:59 AM
glitch427
Apr 9, 2013 10:22 AM
riley6riley
Dec 21, 2008 05:11 PM
SCHOON
Aug 16, 2008 06:40 AM
cat1055man
Mar 21, 2006 10:47 PM
