1970 ls5 454
Old Jul 17, 2008 | 01:07 AM
70 canam BB's Avatar
Default 1970 ls5 454
does anyone know the actual hp/tq numbers for this engine. i know all the literature states 390 hp/ 500 tq. is that correct or is it higher/lower. what components came on the engine initially all i know was it was an iron block iron head possible 2 or 4 bolt main with a holley or rochester q-jet. any info will be greatly appreciated. thanks in advance everyone
Old Jul 17, 2008 | 09:53 AM
Texas Jim's Avatar
Default RE: 1970 ls5 454
I only know that it was 10.25 to 1 compression ratio and 390 HP and it was the first year for the 454 in the 'Vette. Down to 8.5 and 365 hp for '71.
Old Jul 17, 2008 | 08:06 PM
old mac's Avatar
I don't want to give you bad info, so you can go to the link & check it outfor yourself - http://www.auto.howstuffworks.com/1970-corvette/.htm
In case the link doesn't work, I'm finding it with hydraulic cam, small valves & small port cylinder heads. Came w/heavy duty battery.
454/390 for Automatic,
454/460 HP@ 56004-speed, Torque 490@3000
Old Jul 17, 2008 | 08:59 PM
LS-5 was 390 hp @4,800 and 500 ft-lb @ 3,400. Q-jet, hydraulic cam, 10:1 CR
LS-7 was 460 hp but never was released.
From Corvette Bible.
C3 Starship
Feb 5, 2007 03:04 PM
231SIX
Aug 21, 2006 10:18 PM
twitch2k6
Aug 19, 2006 12:53 PM
Bearcamp
May 29, 2006 09:20 PM
71yellow454
Apr 4, 2006 02:57 AM
