1970 ls5 454
does anyone know the actual hp/tq numbers for this engine. i know all the literature states 390 hp/ 500 tq. is that correct or is it higher/lower. what components came on the engine initially all i know was it was an iron block iron head possible 2 or 4 bolt main with a holley or rochester q-jet. any info will be greatly appreciated. thanks in advance everyone
I don't want to give you bad info, so you can go to the link & check it outfor yourself - http://www.auto.howstuffworks.com/1970-corvette/.htm
In case the link doesn't work, I'm finding it with hydraulic cam, small valves & small port cylinder heads. Came w/heavy duty battery.
454/390 for Automatic,
454/460 HP@ 56004-speed, Torque 490@3000
