1979 C3 Windshield Installation
Old Mar 12, 2024 | 02:00 PM
C3PO's Avatar
Default 1979 C3 Windshield Installation
I got a new windshield and am going to install it in the car. There is very little room on top and on the sides. I mean, that if I put the damming tape on there would be about 2 millimeters left to put the goop. Could I just use goop and glue the windshield in, or, is the damming tape necessary?
Old Mar 12, 2024 | 02:26 PM
74HARLEY's Avatar
I'm not familiar with the term "damming tape", are you referring to the butyl tape? That is the glue that holds it in.
Old Mar 12, 2024 | 02:46 PM
C3PO's Avatar
Yes, I am referring to the butyl tape, calling it damming tape. Do you really think I need to put the tape on there?
Old Mar 12, 2024 | 02:47 PM
C3PO's Avatar
And use only the butyl glue pumped out of a grease gun?
Old Mar 13, 2024 | 06:33 AM
The way I understand it the damming tape is only used if you want the original look the way it was built. Do you need to use it, unless you want to keep it original, it's up to you is the way I understand it.
Old Mar 13, 2024 | 09:54 AM
You might also check with a local glass shop to see how they do it.
My rear glass came loose after about a year because all that was holding it in was what I refer to as rope caulk. I don't know if it was what you're referring to is damming tape. I put it back in with black silicon RTV and it's held for the remainder of the 50 years.
Old Mar 13, 2024 | 11:36 AM
C3PO's Avatar
Thank you for your responses.
C3PO
Jan 23, 2024 03:11 PM
Rockitansky66
Jun 24, 2023 06:42 AM
w2w
Dec 12, 2007 10:19 AM
anzolv
Jun 5, 2006 09:21 AM
redvet
Dec 17, 2005 02:20 PM
