1979 vette battery problem
Old Apr 17, 2014 | 10:36 PM
davidsrjr's Avatar
Default 1979 vette battery problem
I have looked everywhere in the forums and through google searches and have not been able to find an answer to my problem. I have a 1979 corvette that will not charge the battery at all. I just took the alternator to get tested and it passed twice. I can start the car and remove the battery and the car will continue to run off the alternator. The problem I am having though is that the engine light is on the entire time, and the battery meter does not show any sign having a charge. I thought that maybe the gauge was not displaying it so I left the car run with the battery hooked up thinking it would keep it charged. After 30 min of it running I turned the car off and when I went to start it again it was dead.
Old Apr 18, 2014 | 07:28 PM
Have you had the battery tested? Are the battery connections clean and tite?
Old Apr 19, 2014 | 10:18 AM
davidsrjr's Avatar
yes I had the battery tested and the connections are nice and tight.
Old Apr 19, 2014 | 02:58 PM
Make sure the ground connections from engine to chassis and battery to chassis are also clean and tite.
Also check the battery voltage at the battery w/ the engine on and off.
Old Sep 11, 2022 | 08:36 PM
Lug knut's Avatar
How did yu fix this I hav same problem
Old Sep 12, 2022 | 08:31 AM
Welcome to the forum. Since this thread is over 8 years old, you'll probably get more views if you start a new thread with your question.
Edit: Oops, I see that you already have. 🙂
riley6riley
Nov 8, 2007 04:25 AM
dominicpom
Jan 6, 2007 03:59 AM
rippfan
Aug 27, 2006 08:33 PM
Carmen
May 17, 2006 09:27 AM
