Gen lite ? Won't go.out
Old Sep 11, 2022 | 09:36 PM
Lug knut's Avatar
Default Gen lite ? Won't go.out
I hav 79 new alternator new battery Gen lite stays on I disconnect battery car stays running that tells me alt is working why is Gen lite staying on im at my witts end
Old Sep 12, 2022 | 08:59 AM
What is the alternator output voltage, both with the battery connected and disconnected?
Old Sep 12, 2022 | 05:43 PM
I am curious how much of your wiring has been changed or altered. To check the dash light operation you can check it by pulling the siamese plastic terminal from the rear of the alternator #1 and #2. white wire is #1, and a fat red wire is #2. With the ignition off position place a jumper wire from term. #1 and term. # 2. turn the ignition switch on and the light should go off, if wired correctly with the battery connected. If not the hunt goes on. #1 term. is a resistor wire from the dash light to the alternator that is powered by the ignition switch going to the dash light. It has anywhere between 2.5 volts to 8 volts (small white wire) the red wires should have 12 volts. When running, the alternator is energized there should be 12 volts on all three alternator terminals, with two 12 volt + feeds going to the light. light should be off.
Old Sep 13, 2022 | 12:24 PM
Key is on engine not running
davidsrjr
Sep 12, 2022 08:31 AM
Hop48
Feb 23, 2010 04:19 PM
riley6riley
May 28, 2007 05:23 AM
TealC4
Sep 26, 2006 12:59 AM
GrtAmrTrkr
May 31, 2006 10:03 PM
