1981 Corvette purchase
Old Mar 22, 2014 | 04:31 PM
Encore00's Avatar
Default 1981 Corvette purchase
Finally did it, picked up a 1981 C3 Corvette. First of all, thanks to all who post on this forum, I referred to them often during my search. Ok so I pick up the car and I'm noticing a buzzing noise I'm thinking it's just a vibration because if I accelerate a little it goes away, now I think it's something else. Any help will be greatly appreciate!
Encore
Old Mar 23, 2014 | 06:50 AM
What area of the car does it seem to be coming from? Does it just go away under acceleration?
Old Mar 24, 2014 | 04:39 PM
Encore00's Avatar
73shark,
It seems like it's coming from the center console, I was out playing around a little bit the other day and it seemed to stop when I pressed the passages power window button! It also goes away when I accelerate or change rpm? Also the battery light is on, the guy who sold me the car said these cars are notorious for that?? Not to worry about it he checked the alternator?
Encore
Old Mar 25, 2014 | 08:48 AM
The buzzing might be the transmission shifting linkage vibrating. The Volt meter lite being lit probably means an alternator problem. Most auto parts stores will test your battery and alternator for free.
Old Mar 26, 2014 | 06:22 PM
Encore00's Avatar
Default Buzzing and alt light
Thanks 73shark, I'm going to replace the alternator over the weekend. The noise I'm hearing could be a vibration, the linkage your talking about is on an automatic?
Old Mar 27, 2014 | 12:21 AM
Did the alternator check bad?
Buzzing linkage is usually associated w/ a 4 spd manual.
Old Mar 27, 2014 | 06:03 PM
Encore00's Avatar
The truth is I haven't tested the alt. myself, I read on here someone had trouble with a blown diode in there alternator which caused the alt. light to go on and a choke relay to buzz so for $44 I figured I just change it and see if that helps.
Old Mar 27, 2014 | 07:21 PM
Is that for the alternator and relay? A good alternator in my neck of the woods is in the $100 neighborhood. Steer away from rebuilds unless you know they're good as most are junk.
Let us know the outcome.
Old Mar 29, 2014 | 02:36 PM
Encore00's Avatar
I install a new alternator and it seems to have solved the problems, the dash indicator light is off and the buzzing noise is gone! As Phil Robertson says Happy, happy happy!
Thanks to the folks who post on this forum
Old Mar 29, 2014 | 04:22 PM
Thanks for reporting back. That's what makes the forum work. Glad you got it fixed.
cedarsales
Dec 12, 2015 08:43 AM
turbocharged97l
Dec 22, 2011 10:49 PM
sritzphd
Sep 2, 2008 11:31 AM
leebay
Aug 29, 2005 11:58 PM
drn
Jun 5, 2005 12:34 PM
