427 Tri-Power vacuum ?
Old Sep 10, 2008 | 05:54 PM
tripowerrookie's Avatar
Default 427 Tri-Power vacuum ?
What kind of vacuum psi should I be seeing out ot the manifold? If I test vacuum off the nipple back next to teh Distributor. If I'm not getting much at idle, what are the most likely culprits?
Thanks for any help.
Old Sep 10, 2008 | 08:37 PM
Default RE: 427 Tri-Power vacuum ?
Welcome to the Corvette Forum.
You are probably getting a ported vacuum which is very low at idle due to it being sourced above the throttle page. You need to get a direct source at the manifold. Depending on your cam, it can range from ~10 to ~18 inches.
Old Sep 10, 2008 | 11:44 PM
I'm getting -2psi at idle.-10 at around 2k rpm's. Gotta chase down a leak I guess.
Old Sep 11, 2008 | 12:34 PM
Here are a couple images of the situation
Old Sep 11, 2008 | 07:41 PM
Are you sure you're getting direct vacuum from the intake manifold? Not sure the engine would run w/ only 2 inches of vacuum. I know the end carbs start to open as the vacuum decreases so they might be a source of manifold vacuum. If you truly have only 2" at idle, then the end carbs would be almost wide open.
h_d_ryder
Jan 2, 2009 09:24 PM
Stovepipe
Oct 28, 2008 08:15 PM
elsie1969
Feb 27, 2008 09:09 PM
RapidRuss
May 19, 2007 10:43 PM
liviz40102
Jan 20, 2006 03:08 AM
