69 427 block identification
Old May 19, 2021 | 06:43 PM
Joe Febbrini's Avatar
Default 69 427 block identification
Hi guys. Having a 69 427 built for my car. It has the correct casting number for the year of the car but why is Hi-Perf truck cast in the block? Any gurus have any idea? Thanks
Old May 19, 2021 | 10:38 PM
74HARLEY's Avatar
The block is cast in pieces, some parts like the bell housing plate have more than one application.
Old May 20, 2021 | 04:14 AM
Ok . That makes sense so that is basically an irrelevant casting then. Thanks 74Harley!!
Old May 20, 2021 | 02:36 PM
74HARLEY's Avatar
You're welcome!
Old May 20, 2021 | 11:14 PM
Welcome to the forum Joe. 👍
Old Jun 2, 2021 | 07:35 PM
Northwoods79's Avatar
For what it’s worth, I just saw something on Motor Trend TV that recommended staying away from the 427 truck blocks. Issues with intake manifold/ head alignment along with others. Wish I would of payed more attention but it’s definitely something to look into.
Old Jun 3, 2021 | 09:20 PM
74HARLEY's Avatar
@Northwoods79 the blocks you are referring to are the 366 and 427 industrial truck blocks. They have a 1/2" taller deck height than the standard big block. They were never installed by the factory in anything less than a ton and a half truck.
Drag racers and monster motor builders like them because the added deck height means a longer stroke crank can be used.
They're also known as "tall deck" blocks.
Old Jun 4, 2021 | 09:33 AM
Great information. How can someone identify these blocks so you know what your working with ?
thanks
Old Jun 4, 2021 | 09:58 PM
74HARLEY's Avatar
Actually it's really easy. Look at the block deck right at spot where the top bolt is for the water pump. If it's close(like 3/8") you have a standard passenger/ light truck block. If your thumb fits in the space (I think 5/8" or so) you have a tall deck.
when I get home next week I can photograph these.
Old Jun 5, 2021 | 08:23 AM
Super information again, thanks 👍🏼
Jenny001
Dec 17, 2019 01:35 PM
gearwood
Mar 6, 2016 03:53 PM
zzfranczz
Sep 2, 2009 02:58 AM
NickD
Jul 25, 2007 10:23 PM
sanddperformance
Nov 18, 2006 03:35 PM
