75 Tachometer
Old Oct 16, 2006 | 01:54 PM
blacknblue's Avatar
Default 75 Tachometer
My dad has had this 75 corvette since 76 and the tachometer freezes at a certain point. I have ordered the circuit board from ecklers but i dont know where it goes. What is the easiest way to put one of these in? Thanks
Old Oct 16, 2006 | 02:13 PM
Default RE: 75 Tachometer
I like to hear about someone hangin' on to a "special car"!
Hats off and Hi-5's to your Dad.[sm=icon_rock.gif]
I don't have the ability to send pages from my manual, or I would.
I recommend that you pick up a Chevrolet Shop Manual, for your year of Vette. You can get them from
www.ecklers.com
www.mamotorwoks.com
An assembly manual helps too.
Old Oct 16, 2006 | 02:50 PM
wrwalke's Avatar
There is no easy way. Best bet is to pull the dash out and dive in from the top of the speedo/tach cluster. You might be able to leave the dash pad and pull the speedo/tach cluster out far enough to expose the wires and circuit board, but I've never tried that (fat fingers).
bill.
Old Oct 16, 2006 | 03:15 PM
Basicly, remove the intrument cluster.
Now that it's out, you can do your work.
Sounds simple, don't have to remove dash pad.
Unscrew, unplug, and remove.
Plug in, screw in, and you're done.
Old Oct 16, 2006 | 06:13 PM
blacknblue's Avatar
ok thanks alot i will try to remove the dash. hopefully i can get it back together in one piece
Old Oct 16, 2006 | 06:30 PM
1969 L46's Avatar
You may have to loosen the steering column and drop it down to allow the removel of the tach/speedo panel.
Old Oct 19, 2006 | 03:41 PM
blacknblue's Avatar
ok, i took the dash apart, got the tach out and replaced the circuit board. the old one was fried in a couple places. but now when i start up the car the needle goes to 2200 but when i rev it, the needle goes down, what did i do wrong, mix up some wires?
myblueheaven
Aug 19, 2012 02:45 PM
aldous
Jan 25, 2008 08:55 AM
blackcorvette
Oct 28, 2006 03:05 PM
