Removing chrome window trim
Old Oct 19, 2006 | 06:04 PM
Default Removing chrome window trim
In order to NOT destroy my windshield and rear window chrome trim, upon removal/instal, I ask!
Does the chrome trim attach by clips, or is it a type of snap-in, to a slot that goes around the perimiter of the glass/weather stripping? I have seen either on other cars. So how's a '80 Vette set up?
Old Oct 19, 2006 | 11:48 PM
pg's Avatar
Default RE: Removing chrome window trim
Hi C3 starship, heres how I you can do it.
#1 you have to remove the side windshield weather strip then
#2 you have to unscrew a couple of rusted in screws then
#3 work your way around the upper moulding removing all the screws as you progress your way to
#4 the other side.
The trim is on the outside of the car, it has threaded places on it, it fits on the windshield frame and is held there by a screw.
I can't tell you how the back trim is held on since mine is a 74. (no glass)
Hope someone else can help you on the rear.PG
Old Oct 20, 2006 | 01:33 AM
Hey thanks pg, I'll check it out tomorrow.
Old Oct 20, 2006 | 02:16 PM
Phill's Avatar
hi starship. the rear moulding is held down with clips. i have two broken ones on mine on one of the corners and i can clearly see the clips. according to my glass guy he believes the glass has to be taken out to replace the clip. he says the clip is held in by a pin that goes in side ways not straight in.
Old Oct 20, 2006 | 03:32 PM
Thanks Phill,
Hopefully, I won't have to pull the glass, I want to take off the chrome to have some plating done, and paint the car at the same time.
vette girl
Jan 26, 2007 02:07 AM
ScrappyJack
Oct 25, 2006 05:35 PM
Pecemkr
Sep 1, 2006 09:13 PM
