'81 quit running on expressway....Ign module?
Old Dec 3, 2006 | 10:45 PM
vintagesurvivor's Avatar
Default '81 quit running on expressway....Ign module?
It was running great, then instantly just quit. Turns over fine, has planty of battery power, can smell fuel.
I think it's prolly the ignition module, but it was just replaced 1000 miles ago.
I replaced the cap, rotor, coil, ign module, wires and plugs when I got the car. (It had quit running on me a month and a half ago, and replacing the module got it running again)
Is there any way to check these modules, and what typically makes them burn out, if that indeed is what my issue is?
Thanks for your help men!
Mark in Detroit
Old Dec 4, 2006 | 10:43 AM
wrwalke's Avatar
Default RE: '81 quit running on expressway....Ign module?
First thing, pull a plug and see if you are getting spark. If not, then start working your way back, check the coil, everything under the cap (make sure you don't have a broken rotor tip). Check all the wires and connectors to the ignition module and the distributor/coil.
bill.
Old Dec 4, 2006 | 11:12 AM
Is there a way to check the module? A test?
Old Dec 6, 2006 | 03:27 PM
wrwalke's Avatar
The best test for me... find a buddy with a working Corvette and try putting his module in your car. Or just convince the wife that his & hers Corvettes is a great idea for just this reason.
bill.
Old Dec 7, 2006 | 01:26 AM
Gary's Avatar
Bad luck there budy..........You can take your module down to NAPA auto parts, they will check it for you for free usually.......Bill was very good at telling you to start at the plug, and work your way back. Also check your conections well. Look closely at all the Pins and female plugs to be sure one is not pullled out farther tan another........Good luck!!!!!!!!, And let us all know what you find, as it could be helpfull to the rest of us out here in Vette land..........Gary
Old Dec 10, 2006 | 02:52 PM
SCHOON's Avatar
You might hane a bad ground causing the problem.
Make sure all the ground connections are clean and tight.
magrag
Nov 19, 2020 09:23 PM
jsanders
Jun 20, 2008 04:44 AM
Thunder
Oct 30, 2007 08:08 PM
badsax
Jun 9, 2007 11:11 AM
my1fast99c5
Jun 7, 2006 12:21 PM
