82 Corvette Crossfire EFI Troubleshooting
Old Mar 9, 2010 | 02:20 PM
82CorvetteCE's Avatar
Default 82 Corvette Crossfire EFI Troubleshooting
Here's a troubleshooting solution for the Crossfire EFI, a USB interface cable that plugs into the 12-pin OBD1 ALDL diagnostic port behind the ashtray and connects to a laptop USB port (I use WinXP):
ALDL OBD1 OBD cable OBDI OBD2 engine codes
If you upgrade the ECM to a 1227747 with a HAM module, you will need to use a serial port DB9 cable interface to your laptop as the HAM module will only work with a serial port, not USB.
I use WinALDL software to check the engine sensor voltages to see if they're up to snuff and within normal operating parameters:
http://winaldl.joby.se/
Anyone knows of another ALDL diagnostic program for the stock ECM 1225550 ?
D3PE
Corvette C6 Z06
Sep 19, 2014 12:01 PM
82CorvetteCE
Mar 4, 2010 12:09 PM
Zero Limits
Aug 8, 2006 05:13 PM
froggy3
Jul 18, 2006 09:36 AM
placidthree
Oct 13, 2005 03:13 AM
