alignment
Old Mar 17, 2010 | 08:31 PM
Sweetness224's Avatar
Default alignment
I'm going to align my 81 corvette in the near future and was wondering where i can find shims for the control arms and also is the rear adjustable? Not much of a thread starter but thanks for the help guys!
Old Mar 19, 2010 | 04:40 PM
1969 L46's Avatar
The shims are available at any tire and alignment shop. The rear also has adjusmets but without the proper alignment equipment, you would do well to take it to a shop. I set mine up by eyeball and then drove to the alignment shop. A four wheel alignment on a C3 runs about $45.00. Money well spent and you know that the job is done as close to factory spec as your vehicle will allow based on the condition of the suspension.
Old Mar 21, 2010 | 10:00 PM
Don't want to rain on your parade but if the car has ever seen salt, the rear toe-in shims will be impossible to get out w/o sawing the bolt on each side of the trailing arm.
The rear camber is usually pretty easy to break loose and w/ a bubble protractor, can be a DIY project. Just be sure to re-torque the bolts to spec.
Old Mar 24, 2010 | 03:02 AM
pg's Avatar
[QUOTE=73shark;63770]Don't want to rain on your parade but if the car has ever seen salt, the rear toe-in shims will be impossible to get out w/o sawing the bolt on each side of the trailing arm.
You got that right 73Shark, the first thing the shop asked me was how long have the trailing arm shims been in there. I told him there stainless and were just installed yesterday!
At that point he said OK we can do it. If they were in there for years forgetaboutit! Gotta love New Jersey mechanics!
78buckshot
Mar 6, 2007 09:46 AM
maine
Jan 1, 2007 10:49 PM
jmtrotzie
Nov 14, 2006 12:39 AM
maine
Sep 6, 2006 03:12 PM
jackson5
Dec 1, 2005 11:57 AM
