Bleeding the breaks
Old Dec 7, 2019 | 03:01 PM
Nbingham's Avatar
Default Bleeding the breaks
We inherited a 1977 Vette that's had a lot of work done but do to circumstances I only know what I can see. That said the break pads have been replaced but the calipers a full of air. I've done countess break jobs through the years but this is the first time dealing with multi piston calipers. I'm using a break fluid pump and have pumped nearly a half gallon of fluid through them but so far can only get one of them clean. Is there a trick to this?
Old Dec 14, 2019 | 09:35 PM
Are you bleeding in the following order: RR, LR, RF. and LF? You are pressure bleeding? IIRC, there are two bleeder screws on each caliber.
Old Dec 15, 2019 | 01:50 PM
Nbingham's Avatar
Yes. I'm working RR, LR, RF, LF. I using a pneumatic pump. Yes, there two valves, but only on the rear and I'm bleeding them inside to out. From what I've researched it looks like its correct.
Old Dec 15, 2019 | 10:26 PM
What's the indication that's telling you that the calipers are still full of air?
Old Mar 24, 2020 | 06:57 AM
mikegocs's Avatar
ive never had a problem with gravity bleed. When releasing the brake pedal , do it SLOWLY,. also check to see the master cylinder level does not go too low.
remove bleed valves and blow compressed air thru them.: a hand pump will work well.
Old Mar 24, 2020 | 06:59 AM
mikegocs's Avatar
Only rear calipers have 2 bleeder screws--not sure why
raystinger
Dec 21, 2011 06:50 PM
JanS
Nov 1, 2008 09:40 PM
brhino
Jul 18, 2006 02:41 AM
tonyb
Aug 28, 2005 09:48 AM
Patrick
Jul 2, 2005 10:15 AM
