Broken lug nut stud, HELP!!
Old Jul 17, 2007 | 07:17 AM
wvesely's Avatar
Default Broken lug nut stud, HELP!!
When I was putting my right rear wheel andtire back on my car I broke the lug nut stud.First time I ever snapped something while using a torque wrench.Now I can't figure out how to install a new one. I have the caliper off and the rotor off, and the old stud removed, but the parking brake mechanism is behind the wheel hub and there isn't enough room behind the hub to get the new stud in and slide it through the hole in the wheel hub.Does anyone know how to do this procedure?
Old Jul 17, 2007 | 08:38 AM
Phill's Avatar
Default RE: Broken lug nut stud, HELP!!
not sure on that set up, never did one on a vette,but on other cars you should be able to rotate the hub and there should be a position where you can slide the bolt in usually you could only do one bolt at a time. hope this helps.
Old Jul 17, 2007 | 03:12 PM
pg's Avatar
Thats a bummer! That never happened to me but I think your going to have to take apart some or all the parking brake mechanism to get that new stud in there. PG
Old Jul 17, 2007 | 04:01 PM
wvesely's Avatar
Thanks for the replies. I should have mentioned I did try rotating the hub but there is no place that will work. Also I don't know how to remove the hand brake shoes as the hub appears in the way for removing the springs. Hopefully someone here knows how.
Old Jul 17, 2007 | 04:28 PM
It's a PITA but doable. Strongly recommend that unless your's is in pristine condition, that you spring for a stainless steel rebuild kit. I think that the kit comes with instructions. The service manual is also helpful.
Old Jul 28, 2007 | 08:09 PM
classicguy714's Avatar
Today while wokingat taking my trailng arms apart I notice someone had replaced thea stud.So remove the paking brake adjuster on the bottom adjust itto the smalles point first, spread the shoes with a screw-driver pull it out. rotatethe spindleso the open stud holeis on the bottom. you will have to hammer the stud up and into the hole witch will dent the (Dust Shield) backing plate. I noticed what was clearly the dent of a stud onbacking platetoday
NickD
Nov 28, 2007 04:48 PM
wobray
Jul 10, 2007 06:54 PM
bobbowtie
Jan 15, 2007 09:45 AM
jmtrotzie
Sep 22, 2006 08:02 PM
ronw60
Jun 27, 2006 10:39 PM
