differential question
Trying to get off differential for rebuild. Is best way to drop with the crossmenber? I removed bolts to rubber bushing, but doesn't come down. I evern put crowbar to it. Don't know how aggressive to be. Am I missing something? Haynes manual is useless. Do metal tabs on bushings have to be bent over? Thanks
Hi halsted, drop the cross member and differential together, remove the front mounting bolt under the U-joint, remove the bolts through the rubber cross-member bushings, pry forcefully, you don't need to bend the tabs on the bushings, they anchor the bushing in the cross-member. the rubber fits in a cup and could be rusted in, you may have to use heat but I didn't have to. I replaced the bushings during the re-build.
