differential question
Old Jan 1, 2008 | 05:43 PM
halsted's Avatar
Default differential question
Trying to get off differential for rebuild. Is best way to drop with the crossmenber? I removed bolts to rubber bushing, but doesn't come down. I evern put crowbar to it. Don't know how aggressive to be. Am I missing something? Haynes manual is useless. Do metal tabs on bushings have to be bent over? Thanks
Old Jan 1, 2008 | 06:17 PM
Default RE: differential question
Ya might drop the gear cluster first and then drop the housing and crossmember together. Less weight to handle, and less awkward.
Old Jan 1, 2008 | 07:41 PM
78buckshot's Avatar
Hi halsted, drop the cross member and differential together, remove the front mounting bolt under the U-joint, remove the bolts through the rubber cross-member bushings, pry forcefully, you don't need to bend the tabs on the bushings, they anchor the bushing in the cross-member. the rubber fits in a cup and could be rusted in, you may have to use heat but I didn't have to. I replaced the bushings during the re-build.
Old Jan 2, 2008 | 08:22 AM
halsted's Avatar
Thanks for help. I will apply more force.
Old Jan 3, 2008 | 09:50 PM
DeeVeeEight's Avatar
Banned
I was always told never to use "more force". I was always told to go get a bigger hammer.
[sm=icon_cheers.gif]
Old Jan 4, 2008 | 05:42 PM
78buckshot's Avatar
The only time I need a bigger hammer is while persuading something on the wife's Ford.
molrock
Jan 31, 2008 01:56 PM
payton34
Jul 4, 2006 10:58 AM
vetdriver
Corvette C5 Z06
May 7, 2006 06:44 PM
TEC1
Sep 3, 2005 04:09 PM
c44me
Jul 1, 2005 08:21 AM
