Driver side window don't work
Old Jun 7, 2008 | 12:21 PM
gigabyte's Avatar
Default Driver side window don't work
79 driver side window won't go up or down. just stopped working. when working the switch I can hear a faint click inside the door. any ideas ?
Anyone !
Old Jun 7, 2008 | 01:44 PM
pg's Avatar
Default RE: Driver side window don't work
Hi gigabyte, I would look at the wires that are between the door and the frame, sometimes from years of opening and closing they brake at that point. PG.
Old Jun 7, 2008 | 09:39 PM
Also check the regulator spring. If it breaks, the motor isn't strong enuf to raise the window by itself. But then you said it won't go down either. Is it up or down or somewhere in between? Don't forget the relay which I think is in the console but may be different in the 79s.
IVAN1215
Technical Diagram Help
Sep 24, 2007 01:50 PM
williadg68
Jun 23, 2007 10:20 PM
98VetteGirl
Apr 4, 2007 04:31 PM
Str8upChevy
Nov 28, 2006 01:09 PM
corvette king
Nov 21, 2006 11:03 PM
