EMERGENCY BRAKE ADJUSTMET
Old Mar 11, 2007 | 06:45 PM
SCHOON's Avatar
Default EMERGENCY BRAKE ADJUSTMET
Need info on adjusting emergency brake on 74.
Thanks in advance.
Old Mar 11, 2007 | 06:54 PM
78buckshot's Avatar
Default RE: EMERGENCY BRAKE ADJUSTMET
I assume you have new parts in the rear, adjust the shoes first so you just feel them drag on the "drum", rock the rotor back and forth to center the shoes. After you have them where you want, take up the slack in the cable with the slack adjuster at the "T" of the cable.
Old Mar 11, 2007 | 10:02 PM
pg's Avatar
Secure the rotor with lug nuts.
Insert adjuster and lift handle away from floor, When tight, back off 7 to 9 teeth.
Rotor should spin without serious drag.
Then adjust cable for final hold, which is tight at 14th click on parking brake handle. PG.
horsepower10
Nov 8, 2007 05:58 PM
horsepower10
Oct 26, 2007 11:07 AM
gigabyte
Oct 1, 2007 10:36 AM
zoom
Jul 2, 2007 05:19 PM
JR Spokehead
Apr 9, 2006 05:07 PM
