Engine noise
Old Sep 14, 2020 | 04:43 PM
Captain Jack's Avatar
Default Engine noise
I'm getting an engine noise with a pattern that is not consistent with rocker arms or valves. Pattern more like a cylinder. The engine runs well with no stuttering on idle, but i can hear a noise that sounds like it comes from deep inside the engine. I have used an engine stethoscope and i can hear the pattern the loudest at the base of the distributor. the distributor was removed recently to add a new tach cable and 45 degree connector. Any suggestions? Also checked all outside pulleys and bearings, but to no avail as all sounded good.
Old Sep 15, 2020 | 09:58 AM
A couple of things come to mind that might cause the noise. One is the distributor bushings might be worn and it could be possibly the oil pump.
When I tore my engine down, I found a broken top ring that was probably broken at assembly.
Old Sep 15, 2020 | 11:58 AM
Thanks, I’ll check the distributor. Idle is smooth, so not sure about a timing problem but I’ll check that too
GRAMPS ZO6
Corvette C5 Z06
Dec 9, 2020 08:34 PM
juice
Technical Diagram Help
Jul 27, 2020 10:42 AM
65Ray0317
Nov 25, 2019 09:43 PM
Toonces
Sep 3, 2014 10:54 PM
kemboz06
Corvette C5 Z06
May 2, 2007 01:56 AM
