Technical Diagram Help This section is for help with technical diagrams from the staff.
marbles in a can noise
Old Jul 26, 2020 | 08:58 AM
juice's Avatar
Default marbles in a can noise
at lower rpm when asking for more power makes a noise like marbles in a can then goes away dealer has no clue
Old Jul 27, 2020 | 10:42 AM
It could be knock or pre ignition. You need to check your timing to see if it has too much advance. If the timing is correct check for stuck weights in the distributor or a vacuum advance problem.
Toonces
Sep 3, 2014 10:54 PM
kemboz06
Corvette C5 Z06
May 2, 2007 01:56 AM
hood
Mar 27, 2007 12:24 PM
lil red corvette
Jul 10, 2006 09:59 PM
94blackC4
Mar 31, 2006 11:02 PM
