Engine rebuild
Guys Hello ,
Really I've been really busy rebuilding my vette
. In my 75 I have GM 350 Goodwrench 4 bolt engine I read that I can use cylinder heads from corvette 96 to get a better performance is that true if not guys what do you recommend to get the most from this engine
regards
regards
Does your crate motor have intake manifold bolts that are vertical or do they go in perpendicular to the head? I think when the small blocks went to TPI, the bolts went to vertical so you'd need to check the '96 heads.
Most of those 90's Corvettes came with the aluminum heads, which should be just like Gen 0 (old) small blocks, I know the LT1s were reverse flow, but that shouldn't affect the heads. I say should because you haven't listed casting numbers or got pics, which should help.
