Engine rebuild
Old Mar 17, 2008 | 03:21 PM
jarrah_12's Avatar
Default Engine rebuild
Guys Hello ,
Really I've been really busy rebuilding my vette . In my 75 I have GM 350 Goodwrench 4 bolt engine I read that I can use cylinder heads from corvette 96 to get a better performance is that true if not guys what do you recommend to get the most from this engine
regards
Old Mar 17, 2008 | 08:36 PM
Default RE: Engine rebuild
Does your crate motor have intake manifold bolts that are vertical or do they go in perpendicular to the head? I think when the small blocks went to TPI, the bolts went to vertical so you'd need to check the '96 heads.
Old Mar 18, 2008 | 09:54 PM
1974corvetteowner's Avatar
i may be wrong but i thought couldnt cross the parts from different generation of engines...meaning anything 86 and newer wouldnt worn on anything 85 and older...but i might be wrong
Old Mar 18, 2008 | 10:17 PM
DryCreamer's Avatar
Most of those 90's Corvettes came with the aluminum heads, which should be just like Gen 0 (old) small blocks, I know the LT1s were reverse flow, but that shouldn't affect the heads. I say should because you haven't listed casting numbers or got pics, which should help.
Ttoptom
Feb 17, 2008 01:31 PM
youngvette408
May 25, 2007 04:16 PM
forzav12
Jun 22, 2006 03:58 AM
Clayton
Dec 1, 2005 03:48 PM
J3d
Nov 9, 2005 10:18 PM
