First time for everything
Old Apr 24, 2011 | 03:30 PM
SCHOON's Avatar
Question First time for everything
Bought new bat cables for my vet and when I went to connect the positive cable to the bat it would not and will not fit over the positive post.
Ever have this happen before?
Schoon
Old Apr 24, 2011 | 05:07 PM
pg's Avatar
Just take the bolt out and wedge a large screwdriver or chisel in the end and spread it apart a little.
Mine has a bolt that goes through the end of the cable.
Old Apr 24, 2011 | 07:30 PM
Maybe it's a negative cable.
Old Apr 25, 2011 | 07:12 PM
SCHOON's Avatar
Thanks PG but I already tried that and it still wont fit.
I just borrowed a tool from my friend that is made for opening up tight cable connectors.
Worst case I will file out the connector a bit.
Shark,
I checked the package itcame out of and it says positive, it is the right length.
Probably made in China.
Schoon
Old Apr 25, 2011 | 08:33 PM
If it fits the negative post, then it's probably the wrong terminal.
Weren't your OEM cables for the side terminal batteries?
YZSoFast
Jun 5, 2007 06:54 PM
mraaron895
Feb 22, 2007 11:06 PM
alex1986
Nov 20, 2006 01:31 PM
mypetu39
Aug 17, 2006 11:00 PM
Danase
Jan 3, 2006 10:23 AM
