gas pedal adjustment?
Old Apr 3, 2008 | 08:06 PM
jsholm2's Avatar
Default gas pedal adjustment?
Hey guys, I have a 75' and my gas pedal seems to be sitting too close to the floor board. Is there a way to adjust the pedal heighth? There isn't even enough room for a floor mat to fit underneath. Thanks.
Old Apr 3, 2008 | 09:52 PM
Default RE: gas pedal adjustment?
I'm not aware of any adjustment. Sounds like maybe the rod that the pedal is attached to is bent.
Have you checked to see if the carb butterflys open fully w/ the pedal fully depressed?
Old Apr 3, 2008 | 11:37 PM
jsholm2's Avatar
no, but I have a feeling it doesn't. If you push the pedal all the way down, it doesn't seem like it accelerates that much. Sounds like it might be a tough fix.
Old Apr 4, 2008 | 12:00 AM
Maybe the throttle cable is too long and/or the peddle return spring is wore out or disconnected. I really don't think it would be all that hard to fix. Give yourself some credit, you can fix it after all you were smart enough to buy a vette....right? Good luck with it. Cheers
Old Apr 4, 2008 | 03:30 AM
extanker's Avatar
did this just happen ?the cable maybe getting ready to break.check the bracket that holds the cable
Old Apr 4, 2008 | 09:49 AM
DeeVeeEight's Avatar
Banned
Is the carpet bunched up under the pedal? Removing floormats and restrictive carpeting can add as much as 40 HP.
[sm=icon_cheers.gif]
Old Apr 4, 2008 | 09:55 AM
extanker's Avatar
ORIGINAL: DeeVeeEight
or a bodyshop can cut the floor panels out and make new one that are one inch deeper then the pedal can go further. JUST KIDDING
Old Apr 5, 2008 | 11:34 AM
batesy80's Avatar
Before you fix it, do you want to race for pink slips. haha
Old Apr 10, 2008 | 12:55 PM
jsholm2's Avatar
Hahaha yea right.
Old Apr 13, 2008 | 09:49 PM
metheglin's Avatar
Didn't Lars used to grab the pedal and pull until it bent forwards? Over the years the throttle cable stretches. I know the throttle cables don't adjust, and a few people have put in adjustible cables. Personally I put a few zip ties around the throttle cable where it attaches to the pedal.
chuck
Mar 7, 2010 05:42 PM
PopPop
May 21, 2007 10:03 AM
mikenann
Nov 16, 2006 08:10 PM
mypetu39
Sep 12, 2006 11:43 AM
Viscito
May 15, 2006 02:29 PM
