Headlight gremlins
Old Aug 29, 2007 | 01:57 AM
Rickcusaf's Avatar
Default Headlight gremlins
So I found out the hard way my battery has a bigger draw on it than I had thought(My guess is it's the old alarm system that's not working). Needless to say when I woke up this morning the car would not start. So I charged the battery for a few hours and drove the car around the block to make sure everything was ok. Now the headlights are stuck in the up position and I have no idea why.
Also, any idea what the two switches under the steering wheel are for? One has a cap that's similar to the caps on my tires and the other is more of a button that you can pull down or push up. Not a clue what they are for and I can't find anything about them in my manual.
Old Aug 29, 2007 | 04:19 AM
78buckshot's Avatar
Default RE: Headlight gremlins
Good morning Rick, it's 5:15 AM here in Michigan. The push-pull **** is to raise the head lights manually without the lights being on, the other one your describing-don't know.
Old Aug 29, 2007 | 12:26 PM
pg's Avatar
Hi again Rickcusaf, is the other one for the "Trip Odometer" pull down and turn it and see if that's it. PG
Old Aug 29, 2007 | 05:04 PM
Rickcusaf's Avatar
Yup, it's the trip odom. The headlights were stuck due to headlight switch being stuck. Luckily it was an easy fix.
Team 4R
Apr 26, 2006 02:56 AM
toroguy
Mar 29, 2006 01:10 AM
jdavis
Sep 3, 2005 11:29 PM
Dans endless project
Aug 17, 2005 04:49 PM
Aug 16, 2005 03:09 PM
