Headlight problem
Old Jan 2, 2007 | 11:23 AM
jen140's Avatar
Default Headlight problem
I have a '79 driver, and the headlights keep getting slower & slower to open... first one side and now both. I would appreciate any help as to where to start (continue)
John N
Old Jan 2, 2007 | 11:29 AM
Default RE: Headlight problem
First, I'd check the vacuume line conections. You may have developed leaks.
Old Jan 2, 2007 | 07:11 PM
wrwalke's Avatar
Ditto what Starship said, and then spray some WD40 or other penetrating oil around the moving parts. You wouldn't believe the salt and road grime that can build up under there.
bill.
Old Jan 2, 2007 | 07:54 PM
jen140's Avatar
Thanks! I've checked multiple vacuum lines, and so far the results seem to indicate that perhaps the seals on the actuators are bad....so I'll try that next. The WD-40 can keep my hoping...while I wait for the seals.
John N
62 Fuelie
65 327/365hp
94 ZR-1
...and the 'problem child' 79
grabie
Jan 29, 2007 09:03 PM
steelman09
May 17, 2006 09:31 AM
steelman09
May 16, 2006 08:19 PM
grabie
Feb 17, 2006 06:35 PM
Daveloves
Dec 16, 2005 02:32 AM
