Heater question
Old Jan 19, 2008 | 10:43 PM
  #11
pg's Avatar
Default RE: Heater question
Hi again, # 1 can you hear the blower motor when you switch it on?
# 2 do you have 4 positions on the switch off - low - med -high. I think most cars with A/C had that kind on switch. Low and med are fused at the fuse box but high has a seperate in line fise on the drivers fender.
# 3 When vacuum is applied to the heat control valve under the hood it lets the water flow thru the heater core, see if you have vacuum at that connection. Does this help? PG.
Old Jan 20, 2008 | 08:17 AM
  #12
DeeVeeEight's Avatar
Banned
ORIGINAL: Rickcusaf
Nothing comes out of the vents at all. The A/C was disabled by the previous owner during the engine rebuild. He took the compressor brackets off and left them in another state. The heater has all components though. At least as far as I know.
Time for some pictures - show us what Bubba did.....
[sm=icon_cheers.gif]
Old Jan 20, 2008 | 10:21 AM
  #13
Rickcusaf's Avatar
Lol! Will do.
Old Jan 20, 2008 | 11:03 AM
  #14
Rich G.'s Avatar
Where getting closer now. Heater and A/c motor are the same. If its NOT blowing then your problem is the motor, power going to the motor, or the switch(or power going to the switch) If it's blowing but not coming out of the vents then that's a whole different problem and different things to check. More then likely a vacuum problem. Which could be as simple as a hose off or a bad switch. And if it's blowing but not getting hot ,that's a whole different problem also. We are like doctors (except we're broke) and need to know the exact symptons before we can diagnose the problem. See if we were real doctors we would just tell you to throw parts at it (like perscriptions) until we got lucky and you changed the right part. Then we woudn't have any money left to pay the real doctors to guess how to fix us.
Old Jan 20, 2008 | 11:47 AM
  #15
Banned
ORIGINAL: Rich G.
LMFAO!!!
[sm=roll.gif]
Old Jan 20, 2008 | 12:04 PM
  #16
78buckshot's Avatar
The difference between us shade-tree wrench types and medical docs., they are still practicing, we actually can make a permanent repair.
Old Jun 27, 2008 | 04:50 PM
  #17
riley6riley's Avatar
I know this is an old post but where does the vacuum line connect to from the heater contol valve?
Old Jun 27, 2008 | 07:15 PM
  #18
78buckshot's Avatar
Hi riley, the small plastic tube that operates the heater valve goes into the firewall and to the heat/AC control on the center console. Actually it starts at the inside control and runs out to the water valve, the heat and AC levers move the control to different ports and direct vacuum to the various dampers and valves to get the results your looking for.
Old Jun 27, 2008 | 07:58 PM
  #19
Thank you very much. I see where it goes into the firewall, it was broken off. I was messing with the firewall grommet and broke off the other small hose. So much fun. Guess I get to pull the center council and try to find the hoses. I am sure it is going to be a fun one where I wish my hand or arm was on backwards. I will keep you up dated.
My vacuum hoses come off the manifold. There are 4 ports, one blocked off, one going to the tranny and two more going to the other places. I am trying to replace them all. Do you have any idea where each one should go? I am trying to get my headlights to go up without me pulling them up.
Old Jun 27, 2008 | 09:58 PM
  #20
pg's Avatar
Here's how the vacuum lines hook up under the hood, PG.
[IMG]local://upfiles/2883/AFB48D49142E4CE9ADAB8B348C09AACE.jpg[/IMG]
cmayberry
May 12, 2013 07:54 PM
majorbob
Jan 25, 2006 11:47 PM
faleure
Nov 26, 2005 03:46 PM
kvette
Oct 24, 2005 01:16 PM
rolliq
Oct 3, 2005 01:25 PM
