Lake pipes on a C3
I've still got mine and plan to put 'em back on whenever I get it back together. One reason is that I still don't have the paint between the ribs on my side exhaust covers.
With the muffler inserts, they really aren't that loud.
The pipe has a bracket near the end of it that bolts to the frame in the keyhole slot that is the same one used by the factory sidepipes.You'll need a couple of rubber biscuits on each side to isolate the exhaust from the frame. You can use the same ones as the factory setup or make your own. The other end of the pipe is clamped to the collector with an integral clamp.
AmericanCarCraft
Aug 2, 2013 10:46 PM
