Losing brake pressure
Old Jun 28, 2019 | 02:15 PM
ghia1974@comcast.net's Avatar
Default Losing brake pressure
I have a 69 with manual disc brakes and for some reason I am unable to get the system to hold brake pressure. I have replaced the 4 calipers and master cylinder and bench bled the master cylinder and gravity bled the brakes. I started off with the pedal being hard and high but over a short period of time (30 minutes driving or so) the brakes are almost to the floor. This is the exact problem I had before replacing the brake components. When I checked the fluid in the master cylinder its right at the top, zero leakage. Any suggestions?.
Old Jul 22, 2019 | 07:40 PM
muffman58's Avatar
It sounds like you have a bad master cylinder since your not losing fluid. I have had brand new ones do the same thing.
Old Jul 23, 2019 | 08:14 AM
ghia, welcome to the forum.i agree.
sb66
Jul 30, 2016 06:47 PM
orangevette
Dec 17, 2013 10:09 AM
orangevette
Jul 20, 2013 02:25 PM
BVFD25
Apr 13, 2009 08:31 PM
Flying Low
Nov 30, 2008 10:49 AM
