lug nut pattern
I have a 74 stingray with a wheel rub problem. I need a 1/8" spacer for my rear wheels as the aftermarket rims are rubbing on the e-brake cable and lower trailing arm rubber bushing. What is the exact measurement of the lug pattern on a 74? IT's hard to judge with the wheel installed (cant hold a tape measure over the center cap and be exact). it looks like 4.5" any advice?
Hey Nick,
Just my two cents worth: I would ditch the wheels and install ones with the proper back spacing. Using spacers on a Vetteis not a good idea. Using spacers on any kind of car with some power is questionable at best. Besides with all the new styles available you should be able to get a great look with aproper fit. Again just my two cents worth.
