mechanic needed
Old Jul 11, 2006 | 05:38 PM
crashbug's Avatar
Default mechanic needed
I'm trying to find someone in houston, a mechanic who is not to expensive. I have a 73 BB that won't start. I think it may be a wire or something not sure. I checked the battery, the starter. both are good. if anyone knows of anyone. please, I would like to corvette run again.
thanks
Old Jul 26, 2006 | 04:26 AM
Default RE: mechanic needed
O.K. dude. If the engine turns over with the starter, you have spark from the distributor and coil, and fuel to the carb. It should run. If either of these ain't happnin', it's a no go. No fuel, check for clogged fuel filter. No spark from distributor, check for spark from coil. (I assume that one day it ran and the next it didn't.) If you're not affraid to get your hands a little dirty, e-mail me and I can walk you through some more quick tests that may help you out.
uleg
Oct 30, 2006 06:23 PM
Lourib727
Oct 18, 2006 02:17 PM
Lourib727
Oct 16, 2006 08:13 PM
freedomvette
Jul 14, 2006 01:35 AM
Lifespace
Feb 27, 2006 05:55 PM
