Overheating question.
Old Nov 22, 2007 | 11:31 PM
Rickcusaf's Avatar
Default Overheating question.
In heavy traffic my temps are steadily rising to where it has me concerned. I've got a coolant flush scheduled for saturday, but I'm not sure if that's what is causing it. (Accidently mixed the dex with the green stuff). Any advice is welcome.
Old Nov 23, 2007 | 07:16 AM
Texas Jim's Avatar
Default RE: Overheating question.
Rick, One of the topics awhile ago, someone here can tell you which one, addressed this problem. I said that I always put a 160 degree thermostat in any small blcok chevy I ever get. The 195 etc. is just too close to disaster for me. Alot of guys have spent alot of money on their cooling systems, like in the topic; "2 core or 4 core" (I think). If you get the stock cooling system operating properly, it'll keep the car cool. I have to say that the C3 'Vette's front end is not very cooling friendly-this has also been mentioned.
Anyway, I'd start with the 160 degree thermostat and see how that works.(a good quality one).
Old Nov 23, 2007 | 07:54 AM
Phill's Avatar
hows the fan clutch. mine was running a bit hot due to an old fan clutch. if its missing the front airdam it may also run hot.
Old Nov 23, 2007 | 11:33 AM
In my case, I always go with a 180* thermo.
Good points made,.....
1. Condition of air dam
2. Fan clutch
3. Thermostat degree options
I'm goin' to throw in another,.....
Inspect the radiator for any obstuctions in air flow.Debris in the cooling fins or bent fins.
Point to concider, is this overheating a new development? If so, the options above may be your solution.
Old Nov 23, 2007 | 10:41 PM
Make sure that the lower spoiler lip is intact and all of the seals around the radiator and between the header and the hood are all there and functional. You want all of the air that comes in the front end and underneath goes thru the radiator. Might have to check the water pump impeller to be sure it's not corroded badly enuf to affect its function. Also make sure pump belt is tite. If you have a fan clutch, check it out. Replace t-stat when you do the flush.
gem48
Aug 6, 2007 07:06 AM
toddg58
Jul 22, 2007 10:42 PM
90vette
Jun 12, 2007 07:24 PM
84Vette
Apr 16, 2006 01:33 AM
BROTHER AT ARMS
Jan 23, 2006 10:13 PM
