Power Seats 1982 Corvette
Old Jun 29, 2007 | 07:09 PM
james smith's Avatar
Default Power Seats 1982 Corvette
where is the fuse located for the power seats
Old Jun 29, 2007 | 10:08 PM
RogerO's Avatar
Default RE: Power Seats 1982 Corvette
No fuse just a 35 amp circuit breaker -Labeled PWR ACCY
Old Jul 1, 2007 | 02:09 PM
does the 35amp circuit breaker control the power windows and power locks also because they work
Old Jul 2, 2007 | 12:07 AM
RogerO's Avatar
No the power locks are on the courtesy light fuse circuit.For your seat check the 2 connectors under the seat.If you have a 12v test light check both sides of the circuit breaker in the fuse box.
Old Aug 3, 2007 | 01:11 PM
cyclic hardover's Avatar
Where is this circuit breaker located? Well I found it all with a diagram from somebody here that I downloaded and saved if anybody wants it. I also unplugged the switch and took a look at it. A first grader can take this thing apart. If the switch is becoming more difficult to use , its because there is carbon build up on the brass connectors that are also esily removable and can be cleaned off with a dremel brush or better yet, the wifes little sandpaper nail file boards.
Just an FYI.
Gary
Jul 4, 2007 12:16 PM
james smith
Jun 21, 2007 06:38 PM
maro69camaro
Jan 10, 2007 07:23 PM
secrt007agt
Nov 11, 2006 02:27 AM
89rdstr
May 16, 2006 09:20 AM
