power seats dont work
Old May 5, 2006 | 12:43 AM
89rdstr's Avatar
Default power seats dont work
well got the new ride home & started cleaning it up. the power seats don't work & the power mirrors only partly work. where should i start? thanks for the help.
Old May 11, 2006 | 12:56 AM
Default RE: power seats dont work
Well, first you need to check the circuit breakers for power seats and windows. Pull them out of the fuse panel and use an ohm meter to check continuity across the breakers, the check for key on voltage at the fuse panel. If they check good, you probably have a bad motor. On the windows, could be the same or the window regulator is bad. It is hard to say without some sort of disassembly.
Old May 11, 2006 | 02:19 PM
89rdstr's Avatar
ok thanks mech259 ive got my fluke ready & im going after it today. wish me luck!!!!
Old May 12, 2006 | 01:18 AM
Correction, sorry, I said window motors when you said power mirrors. Chances are the mirror actuators or motors are bad, had to replace both in my 86 when I got it.
Old May 12, 2006 | 07:15 PM
89rdstr's Avatar
thanks mech259 . where did you buy the mirror repair parts? i will deal with that soon. as far as my seat problem i replaced the seat breaker & the entire left side worked. the rt. side however does not. it is down & all the way back. so i think i will just live with an adjustable driver seat only.
Old May 13, 2006 | 12:02 AM
I think I got them from Eckler's. It was about 3 years ago and, sad to say, with age comes forgetfulness.
Old May 16, 2006 | 03:15 AM
aceosner1's Avatar
what fuse is the power seat fuse?
what fuse is the lumbar cause my dont work?
i know where the fuse bos is (by the passenger sise dash)
but i dont see any fuse in there that says any thing about seats?
thanks
Old May 16, 2006 | 09:20 AM
Power seats and windows are usually circuit breakers instead of a fuse.[8D]
dheller1
Aug 28, 2009 05:28 AM
bostonrobc4
Apr 22, 2009 12:21 AM
harey1
Apr 21, 2008 07:59 AM
james smith
Jun 21, 2007 06:38 PM
Black86vette
Mar 31, 2007 09:30 PM
