Power steering
Old Jan 9, 2008 | 03:34 PM
constitutionalist's Avatar
Default Power steering
Hi All,
I have a '79. In the last 2 weeks my power steering has started to make noises that I would describe as "moaning" or a "low whine." It happens when I turn either left or right. It gets louder the farther I turn, but it still makes the noise even when I turn it just a little bit.
Thoughts anyone?
Old Jan 9, 2008 | 04:18 PM
pg's Avatar
Default RE: Power steering
Hi and welcome to the forum. Did you check the basic stuff, the fan belt tight and the fluid toped up? PG.
Old Jan 9, 2008 | 04:26 PM
Rickcusaf's Avatar
Well, the simplest answer is usually the best I believe
. Have you checked the piston that attaches to your power steering control valve (I don't think the 79s had rack and pinion, but I'm not sure.)? It sounds like it may need grease.
Also, check your belt and make sure It's in good condition. When the belt starts to go it tends to make noise. Check your pulley on the power steering pump and make sure it's not loose. I had that happen to me once.
The easiest way to narrow down where your problem is coming from is going to be to put your car up on a lift or jackstands. Start the engine and have a buddy turn the wheel left and right slowly until you can tell where the noise is coming from.
Old Jan 9, 2008 | 05:24 PM
Thanks y'all. I'll check that stuff out and get back to you.
Old Jan 9, 2008 | 05:29 PM
Rickcusaf's Avatar
Sounds good =) Best of luck and hopefully you find the problem.
Old Jan 9, 2008 | 09:40 PM
78buckshot's Avatar
The GM pumps generally are pretty quiet, your not going to get noise from the other steering components unless their in need of grease or binding on something, I'd start with a new properly adjusted belt and check the fluid for foaming or contamination.
lil red corvette
Jul 10, 2006 09:59 PM
forzav12
Jun 22, 2006 03:58 AM
jetmech09
Jun 8, 2006 09:49 AM
imb1987
Feb 8, 2006 12:38 PM
gs821
Jan 12, 2006 12:27 PM
