problem with starter??
Old Apr 17, 2007 | 09:41 PM
blknblu68's Avatar
Default problem with starter??
well i had the 68 out today and it seemed as though the starter would kick out and whine like a mopar almost, when we tried to start it??
I checked the battery cables and they look nasty!! would this be a reason for the starter acting like that ? i have had gm starters act funny not turn well etc.. but never heard one kick out like a mopar before!!!?? thanx Tony
Old Apr 17, 2007 | 09:51 PM
Default RE: problem with starter??
Sounds like the solinoid is retracting the Bendix gear.
Repair you cables, but I think you'll find that your solinoid is shot.
Old Apr 17, 2007 | 09:54 PM
78buckshot's Avatar
Low voltage caused by low battery or corroded cables may be the culprit but it sounds more like the solenoid/bendix is not pulling in all the way, pull the starter apart and check it out- might be time for a new one.
Old Apr 17, 2007 | 09:58 PM
blknblu68's Avatar
Thanx i figured id replace the cables and then see if i need to rip the starter out!!! thanx again!!
Old Apr 18, 2007 | 01:26 AM
If you "rip" the starter out, keep track of any shims between the starter and the block and put 'em back the same way.
Old Apr 24, 2007 | 01:03 AM
blknblu68's Avatar
Copy that on the shim thing 73 shark!! I did my first motor swap at 16 in a 68 camaro 327-350 but thanx for the heads up!!
Old Apr 24, 2007 | 01:52 AM
You're welcome. Never know who's out there reading this stuff.
Old Apr 25, 2007 | 03:03 AM
blknblu68's Avatar
I heard that shark!! i am a member on the team chevelle web site as well and its crazy some guys that have never touched a wrench wanna know step by step how to swap a 307 to a 600 hp 454 on their first engine swap??? LOL
Old Apr 25, 2007 | 10:38 AM
ORIGINAL: C3 Starship
Repair your cables, but I think you'll find that your solinoid is shot.
I must correct myself here,......
I ment to say...... sounds like the solinoid is not fully engaging the bendix gear.
One other thing, the gear may be stipping out, ya know, the teeth are worn.
Trooper
Sep 19, 2010 08:30 PM
zzz06r
Jun 4, 2009 11:07 AM
cjdietzman
Dec 1, 2007 09:05 PM
Lee Willis
Nov 10, 2005 09:14 AM
jeepin45
Aug 23, 2005 12:44 AM
